Thanks everyone. Frist the rubber hose was bad after replacing it the brakes worked fine for about 20 min then the rears locked again. If I open the bleeder on the master cylinder the brakes will release. I am thinking the master cylinder the fluid was pretty black when I bleed the sys after replacing the hose.
If they only lock up after use, it sounds like the compensation port or ports in the master cylinder are blocked. You should see a small hole in the bottom of the master cylinder reservoir. This small hole is wide open to the wheel cylinders/calipers when the brakes are not applied. As you use the machine and the fluid warms up, the fluid expands. It needs somewhere to go, so it's supposed to go back to the reservoir through that small hole. If it can't, it starts applying the brakes instead.
Two things usually cause this; Either the hole is plugged with rust and junk or, the master cylinder rod is out of adjustment and is being slightly pressed. After just a slight movement of the pedal, this hole is plugged mechanically inside the master so the brakes can be applied. If the master is being slightly pushed all the time, not enough to apply the brakes, but enough to plug the compensation hole, it will cause the problem you are having also.
