Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
Need to know for sure what material it is. Cast iron will hard to impossible to have a lasting repair. If it's cast steel could be welded using preheat and proper techniques.
It's called a link … Depending on the serial number of the machine it could be Notice the substitution ...
12 - Link
Part Number
AT192121
Supported Models
310SG, 315SG
Serial No.
______-953789
Remarks
NLA; ORDER AT324622; ALSO ORDER AT482071, T161036, 40M7066
How did it break? did the pin come out on one side? I'd use a bolt through that pin at the least, that clip is not a good idea.
Take it to a welder if you can't get a solid answer on what it is. It will either hold or not. Most welders should be able to tell the material and not bother if it won't hold.
I bought a similar piece for my old JD 310 at Farmland Tractor in Tangent, Oregon. They are a wrecking yard for ag and construction equipment. They can be quite proud of their stuff but worth a try.
Cast Iron is very brittle, or has little ductility. Steel varies in ductility. When you weld anything the process of cooling the hottest portion makes it shrink. This sets up stresses. Steel stretches as it cools, iron less so.
Cast iron is porous, lots of contaminants interfere with fusion to weld metal.
You can try to have an expert weld it, but you'll save effort finding new, or good used.
