Cylinder reseal, can't get cylinder started back in tube
funwithfuel
Will county Illinois
Mechanic
Just asking for clarification. Did you pack the piston and want to load it right away, or did you wait a couple hours after stretching the piston seal over the piston?
I would think cold vinyl would be less forgiving, but if it had time to relax to its original size and shape, that might be a different story? You're there doing it , I'm just thinking out loud (sorta)
Tinkerer
Nige has me wondering now about Bulldog kits.
That is the brand that I had all the trouble with.
I used a Hercules kit quite a few years ago the first time I packed that boom cylinder.
Mine was a two piece piston. Separate it stack up the piston rings and bolt it back together.
Doug580l
Southern Illinois
You're probably right. The first 2 seals that ripped I did pack the piston and tried to load it right away, didn't know any better. Maybe I all I needed to do was to put it on the wait a couple hours. Next time I'll put the piston ring compressor on it and let it sit a couple hours.
Here's a thought. Try heating the seal in boiling water before installing it on the piston, then after installing it dunk the whole piston/seal assembly in boiling water again to soften the seal. Then while it's all still hot apply the tape and clamp and allow everything to completely cool before attempting to install it.
To add to the heat-tape-clamp ideas how about finding a soda bottle or some such that is slightly bigger than the piston and used a strip cut out of that under clamp? Seems I did that kind of thing on at least one where you had to stretch the seals over a piston to get them in place.
