Izzy Haishonga
sureTake pictures
sureTake pictures
sureTake pictures
Take pictures
It seems like the network is down. Usually this will generate a code. I think you're going to have to call in dealer support. I'm sorry.
okay, thank you very much. I'll continue in the morning and try again. I'll be waiting for the troubleshooting steps.I can post the troubleshooting steps later tonight. They're very specific and detailed. You will need a good volt/ohm meter to perform the tests.
Did you try going straight to crank from the off position? Does it crank if you do. Have you checked the relays above the battery box? Where are your fuses and relays? Early B models were in the cab , later were in an enclosure behind the cab. The correct troubleshooting steps will depend on which model you have. Please attach a pic of fuses and serial number plate. Thanks
I'm still waiting for the serial number and a pic of your fuse panel.okay, thank you very much. I'll continue in the morning and try again. I'll be waiting for the troubleshooting steps.
That new engine ECU might be looking for a sensor that is not there. The upside is, its communicating.
I don't get what mean by thatThat new engine ECU might be looking for a sensor that is not there. The upside is, its communicating.
I'll send first thing in the morning, as its 23:56 night at the momentI'm still waiting for the serial number and a pic of your fuse panel.
