Maybeso
My oil temp guage and water temp guages arent working, although they have power to both. Is there a way to test whether its the guages or the sending unit that is bad or am I missing something else?
And depending on the machine an actual S/N might be even better!You might get better advice with a model number.
thank you, apparently my oil temp guage does work.The engine temp gauge should of course work as the engine warms up and grounding the sender wire should force full scale, if it does replace the sender, if you are watching the transmission temperature you may not see that move under any normal work unless you are loading the torque converter a good bit, Try putting it in high gear, forward shuttle, hold the brakes tightly and run the engine at full load for a minute or two, if the gauge starts up you will know it is good
