I have a Takeuchi 135, 2007, about 3500 hrs. At the start of every days operations the machine will not start unless I put the battery charger on it, set to 140 amps starting, machine then will start right up and run fine for the rest of the day, doesn't make any difference if the machine has been in the shop overnight or outside.I put a new battery in it, no change, glow plugs seem ok, so I'm thinking starter rebuild, anyone have more suggestions before I tear into the starting system?? I'm in Alaska but the machine is kept inside during the winter in a heated shop, so I don't think temperature is the problem.
Thanks in advance, Patrick
