Does a hose have to spring a pinhole leak, on a jobsite, yet when tested before before goin to the job, no leaks evident? Sigh... Anyway, its on a Lowe hydraulic augur. Took hoses off, leak was where the hose comes outta the box, I suspect a rub problem, anyway, took'em off, went to colliflower store, 2 new hoses about 6' long, 1/2 id hose, 4 fittings, 4' of fiber wrap, on 1 end of each hose, plastic armor(on the suspected rub site). Anybody want to gue$$?
While I was in the box, adjusted the chain drive a little tighter, has 2 nuts on the motor slide, that I'm gonna have to bend a cheap open end wrench, to fit!
