Tim A
Hi all any help will be greatly apprecaited. I live in South Australia on a farm and own a 272D skid steer. Up to date has been faultless. Other day went to start it and couldn't select hyd pattern or release park brake, when i push left hand joystick forward it then comes up with flashing exclaimation mark and level two amber warning. which i read in manual was block air filter. So cleaned filter thinking that was problem, put back in and was still there. With further testing found i could select and hyd pattern after the warning lights come on but only right hand side operates and parkbrake will not disenage.
Fault codes i can get off are 3700-3,2474-3,24776-3 and E568-2,E570-2,E459-2,E875-1.
