.RC.
A crappy 2 minute whiney video . I suspect it is normal for an older machine with an enclosed cab to reverberate every vibration. I think down the track I will attempt to add some sound proofing to the cab.
Depends what you are doing , sometimes its not practical to use the blade to stop the machine. Thats why they put brakes on them.who uses brake to stop dozer what is the blade for, very little wear there always have hand on lever and replaceable edge with out pulling tank and steering top.
To true, in steep country you everything at times.i do. in steep hills you need everything, sometimes all at once, especially when doing brush work
I agree 100% ,was taught that years ago.In my opinion resting your foot on the brake pedal is a bad habit,but it’s not my machineto each his own have worked very steep ground and in strip mine d8k and d9h i have 5h 5b 6c and 6d and 7g still have paint on petels perfer the blade brakes for lowboy. lot smoother with blade, hate the jerts.
