Subtlevalley
Hello!
I have a grey market CAT 305,
#305CDCR00532
Runs great, but 9 times out of 10 it won't shut down by the key.
Shuts down fine when I push the manual shut off at the fuel shut off solenoid.
The main issue though, is that the battery doesn't charge while the engine is running with the key in the run position, but as soon as I turn the key to the off position and the electronics switch off (engine keeps running) then the alternator charges the system perfectly.
Anybody understand what's going on here?
I've pulled the alternator and had it bench tested at a shop - tested good.
I've cleaned and/or replaced all the contacts at the alternator.
Replaced the ground cables at the battery and chassis.
Replaced the positive battery cable terminal at the battery and all the fuses test good.
The fuel shut off solenoid was replaced 100 hours ago because the machine used to charge but not shut down.
The new solenoid worked fine turning the ignition off consistently for about 20-30 hours before the key stopped shutting the machine down again.
#305CDCR00532
