I had the 1999 GMC Top Kick dump truck with the ten speed transmission. That transmission requires double clutching. I can't do that much clutching anymore so I sold it three weeks after getting out of the hospital. I replaced it with a very nice Sterling with cold air and a Allison automatic transmission, and a Cat engine. The truck has 84,000 miles on it.
I needed a reason to get out of bed, and the truck needed better brakes. I replaced the two rear automatic brake adjusters and adjusted the front brakes. Now she will stop on a dime.
There was also a notable, " catch", or hard spot, in the steering when coming off of center. I was guessing a tight kingpin and I greased every fitting from front to rear. That problem turned out to be stripped splines in the Pittman arm where it fits to the steering box shaft. The shaft splines were in good shape. This truck has two steering boxes. The left one is the primary while the right one is a slave, and works opposite the primary, much like the way you swing your arms when you walk. The right arm was the culprit.
With my sore condition, changing the right side Pittman arm was a chore indeed. I had a puller to separate the pittman from the shaft., no big deal. but swinging a ten pound sledge to get the tie rod loose put me back to bed. I had a ball joint separator on a air hammer, but it ruins the rubber on the tie rod end.
All that the truck needs now is a tail light lense and a turn signal flasher, and she will be ready to work.
When the new pittman arrived, it was no trouble to install.
