Troy Panetta
Troy, did you follow the lines from #1 and #3 back to see where they go? The injection pump takes the fuel in the end and returns it on the other fitting, like THEpumpguy said, but that doesn't mean somebody didn't change them around, obviously this has been messed with recently, and possibly never got to work right, which might be why it was for sale. Obvious clues: non stock filter, pump, hourmeter with 10? hours, rebuilt/different injection pump with different mounting bolt hole drilled (pumpguy?)
What's the quick coupler with the hose clamps right in the middle of the pic? I hope that's for "spit swapping" the coolant to start it in winter time.
After tracing the lines, how about an explanation, or better yet, pictures of the hose routing from the fuel tank to the injection pump and back again, there could easily be several issues with this one.
so the routing is from the tank to the first filter, through the fuel pump around the motor to the glass filter and then back around the motor to the stanadyne pump. the return side goes to all the injectors and then to the fuel tank.
Hour meter reads 8010 hours and i think its accurate as it still runs.
The quick connect hose runs to the heater inside of the cab from the radiator
