92U 3406
I would take what ever comes cheap since the body always falls away long before the engine dies. Unless you are towing at max capacity all the time i dont see the point of the new diesel trucks. And even at that you guys need different licenses to do that so in that case you might as well have a real truck. In quebec anyone with a regular license can put 30 000lbs behind a 550 and go.
I think Alberta is more or less the same as well. Seems we go by number of axles rather than weight when it comes to licensing.
