I don't have the s/n in front of me but will get it. The machine needs some adjustments and trouble shooting. The engine needed repair the cylinder head was leaking. After a new gasket was installed the head was checked and put back together. Now it turns over and will finally start after you try it 3 or 4 times. Timing was set by local dealer. They said the rack was bent and the tech tried to straighten it. Next the hydraulics seem slow. The travel and steering are not right either. It is sluggish and wants to steer to the right. When pushing against a pile the track will break traction but the tracks are quivering not a steady roll. We are warming the machine but this is the way it acts all day. The hour meter shows 5500. Not sure if that is right , the bucket has some play and the loader controls have a lot of play. I will check for service codes and get the s/n tomorrow or over the weekend. Just curious if others encountered similar issues. I am suspect that at one time it was run low of hydraulic oil. This machine uses one reservoir for travel and implement I think.
