Just an FYI for anybody out there. The dot on the angle sensor needs to be opposite the wire harness of the sensor. The little spring clip that sits on the "A" sensor shaft that fits into the slot inside the pump needs to be tight (should be replaced anytime the "A" sensor is replaced). Also when the sensor is out put a screwdriver into the slot of the pump and try and turn it back and forth. If it turns more than a few degrees then there is wear inside the pump in the feedback linkage.
Some of the early Hitachi manuals had it backwards. Thanks for explaining the proper way.
"Some issues" is an understatement. Yes, I agree with excavator that these machines are extremely complicated considering their vintage. And yes trying to troubleshoot from the seat of our pants can be almost impossible at times. Like excavator, I believe if I'm not there to touch, feel, see, taste, smell and hear the machine, then troubleshooting with an individual who does not understand the inner workings of these machines can be frustrating at best. Anybody wanting to work on their own machines should not even consider touching them without purchasing a tech manual. Diagnostic software would be highly recommended also because it can speed up the troubleshooting process as well. I would personally recommend buying a Deere 490E Operation and Test manual for the EX120-2, -3 Hitachi's because they are easier to use and understand than the Hitachi manual.
When they were "new" they had some issues, since they are now almost 30 years old I think a large part of the issues are going to be wiring harness related. I find quite a few harness ends having problems and should be replaced. They are available from Deere.
For those of you that have had negative experiences with dealers or other professionals will need to be patient with our recommendations because like mentioned earlier we are not there. I myself will try to throw out some simple things to do on these machines to help narrow down issues without having expertise or special tools, even though that is not the way I would approach troubleshooting that particular machine.
Sorry, venting
