J.Hunt62
engine wont start . no power to lift pump or injection pump. I suspect the vp 44 relay but I cant find it on the machine. could anyone tell me where this relay might be located. thanks
Welcome to Heavy Equipment Forums, J.Hunt62.
I merged two of your threads here, and moved the discussion to Excavators, from General Industry Questions. The one in the Test forum I'm just going to close. Hopefully some more people will see it and you can get all the advice you need.
If you're referring to the little eyeball looking icon next to your threads, all that means is that you've made a post there, so now you are 'watching' that thread, and you'll see a notification when someone makes a reply.
