case 9010 B computer not powering up
ebohy
michigan
I have a 9010 B the moniter is blank I am getting power to it but I dont think the computer is sending the signal down to it are there indicator lights in the window on the front of it
laycobeau
Tulsa Ok. beau.bowlan@lei-corp.com
Lead electronic technician
Are you sure about power and ground into the monitor? I think some of those may have a fuse inside. Sounds like broken(loose) wire or blown fuse.
Of course I've been wrong about half the time this year.
ebohy
michigan
I have power to the monitor even when the key is off thats why I looked at the computer to see if it was powering up but when I saw the window on it with no lights on I thought maybee it sends a singnal to power up the monitor I need to find a wiring diagram for it
ebohy
michigan
I was using the frame for my ground I finally got more info on the power to the controller and it should have a red and a green light on in the window so now Im looking at the power and ground to it but i wont get to it for another week at least thanks for all your help
