Bakelly78
After some thought and air box inspection, going to remove blower. Blower looked dry with a quick inspection, but suspect enough oil is getting by to cause this. Will update if that was it when finished. Appreciate all the help!!
Well if it did overheat it may have damaged some rings or the pistons where you could not see with them still in cylinders.Seemed to happen suddenly I think lol. It’s been that way for last two years and could run for another 10 that way I’m sure. Thought my operator said he had overheated engine, so I thought the head cracked and that was the cause. Had head redone and head was in decent shape when it came out. Checked blower real quick and dirty before I removed head, so thinking I need to check it thoroughly now...
Not sure if anyone here has tried or heard of one solution to the slobbering of the 2-stroke Detroits.
I was told one time that for one used in lightly loaded application one, I won't call it a cure but a work around, was to install restriction plates in between the exhaust manifolds and the heads. Basically say an 1/8 inch thick steel plate with a bunch of small holes. Idea was to create a bit of back pressure to reduce the amount of "cooling air" from the blower going through the engine that was keeping the cylinders too cold.
Two problems I could see with this is first deciding how many and how big of holes to put in the restriction plates, guess it would be by trial and error. Second would be if you needed to get full power from the engine for a short time I could see it overfueling due to lack of air flow.
Wanted to try this on a small genset with a 3-53 that was used to keep a big genset warm nights and week-ends and never needed even 1/3 of it's rated output but could not get powers to be to agree to a test of the idea. Instead they decided to just stick in smaller injectors, believe we went from N45's down to N-35's. But that did nothing in my mind because the governor was already adjusting the fuel output to what was needed to maintain the RPMs. Injectors only limited the maximum flow. If I'm off base with that logic I'm open to correction.
If this idea would work I could picture an option of installing something like an exhaust brake in the exhaust where when max power was needed you could just flip a switch to open the butterfly to free up the flow.
Would it work on the two strokes? Good question. By design, the blower is both exhaust and intake. Piston top goes below the cylinder ports, exhaust valve opens, the blower forces out the exhaust gasses from the combustion chamber, and just before the piston top raises and closes the ports the exhaust valves closes allowing the blower to give the combustion chamber a charge of air for combustion. I'm just wondering if restricting the exhaust ports of the head would adversely affect this process.The exhaust brake idea makes good sense. A lot of the newer trucks do the same thing for warm-up. But would it work on the 2 strokes?
Nah- just dont' work when its cold. Or hot. Or raining. Or if the mosquitos are out. Shoot, just retire and fish......
I like money $!Money! LoL.
