The 110s in the old Euc quarry trucks were slobber boxes, except when they came out of the hole then cleaned up, the same 110s series engine on a Fleeting Service tow boat would dribble some from air box drains but had no inclination to slobber as when stuck on a line of tows pointed Upstream were running props to keep tension down on anchorage lines, pedaling Downstream they were often shoving deep draft hulls thru the muddy bottom and still shoving hard or in maneuvering had prop wash to drive the boats sideways. Seldom were they left to idle for long periods except locking out. Can say they are quite a good marine engine, HATED Dirty conditions, were some OK in HE when were beaten on day in day out but again dirt would beat on them. The EMDs are a different breed altogether but just the same a Saltwater Chevy!! My own K100C 8V92 soured myself on DDs.
FIRST Rule learned when taught to drive a DD in a 8664 FrtLnr, Open door, Insert Hand to door frame, SLAM Door THREE Times to be good and mad when drive the Shifter/Throttle.
