Bwar77
Hi guys - ran into a clutch problem with my JD 510b today. Here’s the story - I hardly use my clutch. I don’t move far and mostly use the hoe for digging stumps and rocks. So I leave it in first gear (4 speed) and only use forward/neutral/reverse. Today I used the machine for the first time this year (haven’t used it since last fall), decided I needed some more speed to move some stone, pushed in the hydraulic clutch, shifted to 2nd, released the pedal and that was it. I have no movement forward or backward. The clutch seems to have a slight chatter, but not often, when revving in gear. And will rock forward a bit like it wants to go when I rev it. But I have no power to move. It’s almost as if my clutch didn’t return when I pushed it in. Clutch petal is free to move in and out and feels the same as it always did. Prior to this, clutch was strong as can be, could run into a tree and the tires would dig till i sat on the axle - been like this since I bought it 10 years ago. Contemplated taking the plate off the bottom of where I think the clutch is but I’m not sure yet how to fill it - I believe it’s a wet clutch. I let it sit for the past two weeks (was on vaca) hoping it would magically fix itself but no such luck. Could the clutch be froze or stuck on the splines from when I disengaged? Or what else? Any suggestions?
