Loader with a backhoe
cuttin edge
NB Canada
Finish grader operator
A recent post about a Hough loader has sparked my memory. I remember a motel here that had an old Hough or Payloader. The smaller model with the rear steering. It had a backhoe on the back. Was that an option at one time, or would that have been a homemade setup. I was only young, and never got a close look. Not sure if it was run from the cab, or if it was like those ones you see on farm tractors.
JPV
S.W. Washington
I remember our old neighbor had a nice Case 450 size track loader that had a backhoe from the factory, that was a neat rig. I have never seen another one. I have seen pictures of John Deere track loaders with backhoes. I have never seen a wheel loader with a backhoe but could see where it could work pretty good for certain things.
JPV
S.W. Washington
That is awesome, new one to me! Looks like a heck of a backhoe, if you had 2 operators on the same page you could really dig a ditch.
wornout wrench
canada
I think it was about 1971, we were living in a logging camp. They had a Cat 966C with a backhoe on the back. At the time they were still building roads with American Shovels, hydraulic backhoes had not made it into the main stream logging yet.
It was a funny looking thing to be sure and if I remember correctly its main use was for replacing culverts.
RZucker
Wherever I end up
Mechanic/welder
Knew of a guy back in the 70's that had a rear steer Case W-7 (?) with a backhoe on the rear that did exactly that, had a helper in the seat to move the machine when he was trenching. He could really cover ground that way.
JD955SC
The South
View attachment 212111 Just something I came across on Craig’s list
Hoes were pretty common on track loaders.
I have run a John Deere 555 track loader with a backhoe (pile of junk) and Dad told me he ran a real old JD one and tore every hose out of the machine digging out an old garbage dump when putting a bridge in
I had never heard of wheel loaders with backhoes before though very interesting
cuttin edge
NB Canada
I've always wanted to go to BC. Looks like nice country. I have friends in Vancouver, but I would like to see the interior.
Tags
Connecticut
It always seemed to me a backhoe oe on a wheel loader with a center pivot wouldn’t be the best, due to the stress it would put on the center pivot, plus having to sit over the radiator must’ve been a real treat, much less having to move ahead by climbing down off the hoe, then up into the cab, move ahead, climb down and back up to the hoe, only to have realized you didn’t pull ahead far enough or pulled ahead too much. Have lots of experience with the Kubota 520 wheel loader with a side shift hoe on the back, the center pivot and oscillating joint take a beating, but it does have a swivel seat...:D
