Case 580CK Bucket Teeth
Offshore 1
I had a tooth fall out of the backhoe bucket the other day. I was initially really confused at to how it was retained in the bucket. Turns out a rubber o ring type material is inserted into the holder, and the tooth is then installed, presumably with just friction holding it in place. The backhoe is a 33S, and the tooth type is a Pengo 6-14B. Does anyone have any idea where I could find these rubber retainers, or whether the is an alternative way to hold the teeth in place?
Offshore 1
Could be wrong but I think that's similar a cat stile on my mini hoe buckets ?
Thanks for the reply. You may be right, but from what I can tell they are pretty rare. Searching the part number on the tooth brings up nothing. Definitely a strange one. Might try some large o ring lengths down each side of the holder and see if that works.
Ronsii
Western Washington
s/e Heavy equipment operator
If you can't find them anywhere then I'd just carve one out of rubber... saying that is what it's completely made of and you have a close idea of what it is supposed to look like...
Tinkerer
Like TheWeldor sez, change the shanks for normal #23 style bucket teeth.
They are normally on Case buckets.
The teeth are cheap and readily available everywhere.
New shanks can be purchased for less than $20.00 each.
I looked at Pengo teeth and all I saw were auger teeth.
I am guessing that you don't have a OEM Case bucket on your 33 hoe.
Or someone had cheep access to auger teeth and shanks.:rolleyes:
