CANNONMAN1
so, I kinked the end of the steel line in a NH 575E Backhoe. The lines are incredibly expensive from NH. It looks like the end hose is attached to is just soldered/sweated on. Can you buy just the end an resolder it on. I’ve plenty of length of steel line. If so, is there a certain solder to use? Thought about just heating up old end & removing & reusing. Thoughts?
