DB2
Blowby causing increased engine temp? Not sure with this new stuff
ThanksDon't give them the daily usage figures, just give them the gallons of oil / gallons fuel figure over weeks or a month and hopefully you can get satisfaction that way....
Average the fuel vs oil added figures over a week/month if it helps to smooth out the "bumps in the road" that you might see in the daily data.Don't give them the daily usage figures, just give them the gallons of oil / gallons fuel figure over weeks or a month and hopefully you can get satisfaction that way....
That is more than I could tell you, I will ask the mobile.I have seen an issue like that with valve guides. Working a lot of hills can leave oil sitting on top of the head at times and slows down the drain back to the crankcase. Does this machine have a positive crankcase ventilation and a filter?
