ok I found a wiring harness finally for my 580C it looks the same, had a few extra breaker on it but all the wires look the same from what I can see of what was left of mine, but here my problem when I get to where it goes to the clutch cutout this one came with a second harness 2 pieces top and bottom, but looks like mine was a one piece and the clutch cutout was wired through it so now I'm trying to figure out if both the wire on the clutch Solenoid are hot or does one need to go to ground cause there not a pig tail for the solenoid. And I keep reading about a Diode but this wiring harness doesn't have one any help would be so helpful and if I didn't make this plain just ask and I will try and correct for you to better understand. thanks
