90 degree fittings
92U 3406
Western Canuckistan
Wrench Bender
Anybody know of a good way to keep 90 degree ORFS and JIC hose ends to stay in alignment when tightening them down? Seems like its always the one hose in the most ignorant spot that wants to rotate with the nut.
Most of the 90's I've seen are flat on the sides so you can put a wrench on them. When they aren't I still try to fit a crescent wrench or pliers on them even it has to go diagonally. Depending on room a chain vice-grip may work too.
Can you get a wrench or vice grip on the curved part so you're holding the vertical and horizontal sides of the fitting? Maybe put a small rag on the fitting if using a vice-grip.
Maybe I'm not understanding the question but usually all you have to do is hold the hose with you hand while tightening the swivel nut on the hose when connecting the hose to the fitting.
92U 3406
Western Canuckistan
Wrench Bender
I always seem to get the big hoses (like -16 and up) that the nut just does not want to move freely on the flange. Usually just try and jam a prybar against it so I can lock it down. If not, the hose usually just spins with the wrench. Now the hose is putting tension trying to loosen it off. Sometimes (like on drive hoses for skid steer pumps) its next to impossible to get something in there to hold it in alignment properly.
Bls repair
S E Pa
Equipment operator,mechanic
6B726889-4203-4522-9C6C-B678889D27B0.jpeg What about making something like this to fit over crimp part of fitting to hold it from moving
Bls repair
S E Pa
Can you get some lube between the outside of the flair and the inside top of the nut where they meet?
JD955SC
The South
I know exactly what you mean, very aggravating when it happens. So far I’ve made do with big channellocks and prybars. It’s very difficult because you need 3 arms to manage the wrench for the nut and the bracing tool and hose
