Dave Z
Hi folks - I'm in the market to buy (or build) another service truck - probably my last. Anyway back in 03 I bought a new 11' IMT Dominator II crane body along with a 3820 crane and bolted it all to an older IH chassis. Since 03 I had to replace 4 of the doors because of rust at the bottom of them where IMT rolls the steel into 2 plys creates an envelope for crud to lay in and rot them out - same old same old. Also had to replace all the diamond plate that forms the rear bumper/long tunnel cabinet due to rotting out - other than that its never had a crack in it and has held up well. I was considering going to Stellar this time but ran into a guy yesterday with an aluminum stellar body that was spider cracking at most of the cabinet corners - he also showed me where the corner cabinet directly under the crane has cracked and been rewelded multiple times. Was wondering if anybody has any feedback on how Stellar's steel bodies hold up to cracking and corrosion resistance - and door rust. Im running SE PA where the state loves to use all types of anti icing compounds in the winter and would like to put something together that will last at least 10 years without having to fix rust. Also if anybody knows if the bolt pattern for an IMT 3820 crane is the same as a Stellar body. Any feedback is appreciated. Thanks
