Ok that makes sense. When draining. I have the issue when filling. I never did drain the radiator, it was empty on its own. Completely empty. I'm assuming from the leak. When I pour in coolant. at resorvoir, I can almost immediately hear water trickling in pan and the level rises on dipstick. My question is: If the leak is up higher at the head or camshaft galley, wouldn't the radiator level come up and stay at the level of the leak instead of leaking completely out below the level of the leak? That's what's throwing me off. A block and a radiator are basically 2 containers linked with a tube at the bottom. Even if you do have to pull a plug to drain the block wouldn't the radiator retain the same level as the block retains? That's what keeps making me thing the leak is below radiator level. The only possible asnwer is if it has to be running for the radiator to fill and thats why no water is going in the radiator? Doesn't seem too likely. Sorry to keep hammering on this but I learn a lot from you guys. Just a note- engine runs like a Singer sewing machine. Hate to just write it off with so few miles.
