12.7 Detroit
funwithfuel
Will county Illinois
Mechanic
Should be 2 fuses. 1 for each set of 3 cylinders. If you lost 1 it shoulda kept running on 3. If you dont have any error codes, pull the sir compressor discharge hose off. Crank the engine and see if you get delivery. If the accessory drive fails you lose compressor and fuel pump. Dragged a lot of Freightliner off the highways for this common problem
LN Pipeline
Montana, USA
My neighbor had this problem with a 12.7. Ended up being low coolant. Guess there is a shutoff switch for this?
I don’t know if your problem is that simple, but you could check.
crane operator
sw missouri
Will it crank, but just not start, like its out of fuel but you have fuel? Mine had a rubbed through wire behind the air compressor. I think its the wire that ran from ecm to crank sensor on the front of the engine.
