Don k
I am changing all fluids in a JD 310SG. Two of the drain plugs are boogered up. They are about inch and a half diameter plugs with what used to be a place in the center where you used a half inch drive to remove it. What is the best way to do this? Is it safe to weld a nut or bolt to it? Thanks, Donald
