Genie fuel cutout relay (5 pin) problem
gatorsby7
dunnellon, fl
retired
1995 Genie Z45/22 Serial # Z-45-002312
LSG423 Ford Industrial dual fuel Gas/LPG, with carb and DIS ignition
caveat: I am not original owner, possibly some creative wiring done in control box. I bought the machine
in a salvage, non-running state.
in order to get my machine stay running, i've had to run 12v directly from battery to anti-diesel solenoid.
(fyi, i didn't run power to the electric fuel pump because right now i am running machine from a little gravity fed tank
while i clean the real gas tank).
With Gas selected on Fuel Select switch and Key On, i have 12v at TB38. At fuel cutout relay (CR6), i have 12v at Pin 30.
I am not seeing any voltage at Pin 86. It looks like two Green/Y wires go to Pin 86. It seems Green/Y are ground wires
on this machine. Maybe I'm not understanding how the 5 pin relay works.
I checked the fuel cutout relay for LPG (CR7) and it seems to operate exactly the same.
Any suggestions on how to troubleshoot this.
gatorsby7
dunnellon, fl
retired
as i've thought about this problem a little more, I'm wondering if it has something to do with wiring at KEY switch for ground/platform and/or wiring at STOP switch. There's also a loose wire, which I haven't chased yet. Here's some pics.
gatorsby7
dunnellon, fl
retired
there is a broken diode laying in the bottom of the control panel. I'm now wondering if that loose wire should have a diode on the end of it and connect to key switch? anyone got an old Z45/22?
gatorsby7
dunnellon, fl
retired
after realizing the loose white wire went to TB23 (keyswitch power), I connected it to the key switch on the same wire/post that powered control panel side. that fixed the problem with having to jump the anti-diesel solenoid, however it may have created a new problem. I can kill engine with control panel STOP, but platform STOP does not kill engine.
