And I don't think I'd do it that way agin! Had 7 file drawers I had mounted in the shop, to put some of the mess in(got 'em at auction fer a dollar!). Problem is, they gots no top or bottom, and the birds(swallows) and bees(wasps, mainly) likes to nest in the nooks and crannies. So, figgers me, I'll take some sheet metal, and make a pest blockin shield fer the bottom...
Needed something like 20 inches wide, so I looked up the price of a roll of flashing $50! So I figgers I can beat that! Gotta old file cabinet fer $25, about 3 miles from home. Cut it up with a harbor freight steel cutting circular saw blade($18), it did a pretty good job. OK, why TF is this thing not falling into the pieces I just cut outta it? Frame was spot welded to sides, and drawer slides, with about 25 spot welds per side!
So I cut and I ground, and cut and ground, fer about an hour a side, to get the flat metal I needed. Another hour of clamping, and buzzing in about 16 sdst sheet metal screws, and the bottom is done. Now alls I needs is some free boards fer to cover up the tops! (i gots a line on some, on CL, only a few miles from home...!) I guess I'll find out how much I spend on the "free" tops, when I cross that bridge...
