Oldcatpusher
D6h 3zf00772 steering isn't responsive at idle or wot. Barely tightens tracks when you steer in neutral. Linkage is good to valve on differential steering. When tilt is maxed out on blade steering works. Which valve could be causing me trouble? I'm not very experienced with hydraulics just enough to know it's not the steering motor or steering valve but some other valve not prioritizing the steering.
