This is just one of many post about these machines found when doing research
but i agree it does not solve the problem of trying to stop a stalled machine on hilly ground.
i am going to try to set up a braking system that can be used if the machine stalls something like a disc brake setup on a monster truck only putting this on the brake shafts sticking out of the transmission = see picture
Dozerbill63
Well-Known Member Joined: Nov 12, 2012 Messages:
65 Location:
Repton , Al. Brakes ?
You don' t even need brake pedals on a 450 or 850 , I removed the pedals completely off both of my 450s , you steer case crawlers with the levers , true enough the pedals are for quick turns , away from trees , basement walls and such . If you do not know much about the brakes ,they can get you killed . Loading case crawlers on trailers is the most dangerous thing you can do using brake pedals . If you push the pedals half way , you will free travel , pedals must be pushed all the way. You are suppose to steer with the levers PEROID !
