funwithfuel
OK from the bottom you can clearly see a Spacer plate that tows us you have a twin disk clutch. With the information that spud monkey provided you should be able to get that rascal adjust it up tight.
Why is the adjuster out of your clutch. If you put a 12.point 3/4 socket and push it in you should be able to turn that screw with the pedal down to adjust your plate.
