HD21A
- Joined
- Jan 24, 2010
- Messages
- 50
- Location
- Chillicothe, Ohio
- Occupation
- Manage and operate family farm
Wille I have read your answers for 2 years, now I have a problem. Have had the s-65 for a year and everything perfect.1999 Genie, Ford LRG-425 EFI engine. Was going up in high speed rate, the engine started to miss, black smoke ,running rich and missing, gas, got down. Tried a restart, nothing. If it sits several hours, will restart, rough black smoke then smooth out, go high rate, rough more smoke, smooth out but put a load on it , die and cough and then smooth out. Getting return gas to tank from pressure restrictor. Started downloading manuals and reading, This has the Bosch carb. If flooded, can switch to lp (No lp tank connected) will start and switch back to gas and sometimes it continues to run on gas. I show a default code of 23, but there is none listed, a 22 and 24, no 23. I have one gauge problem. The water temp gauge was always low, now it is doesn't read. Measured the resistance to the sender, ZERO ohms. Will check the movement by putting a 500 ohm or smaller resistor to ground. There is a 33 default code about the temperature sensor. Would a faulty sensor cause this problem? Though about using MAS cleaners to clean the throttle body but thought I would ask before doing it. I have taken the air filter and lines off and the governor butterfly seems to be working when running. Haven't tried it on lp yet, have a fresh tank for the grill, Will wait for you replies first. We use the Genie on the farm for house and barn rebuilding. Bob Chillicothe, Ohio
