Have an older CAT excavator with 3208. Since the day I got it, it was realized the engine "can" spin more RPM than was intended on that machine. How high? I don't even know because when I got it, I started ramping the throttle with the lever I realized it didn't seem to max out and sounded like too many Rs for it. I put a tach on it and sure enough, I can overspeed it.
Forever, I have been setting max RPM by ear, but I need to put someone else in it and need probably fix this correctly. Any documents and such out there on this? I do have a pile of books on this machine and engine, but I suspect something has been "screwed around" on it. It does seem to apply a governor, or at least boost fuel when needed. The max RPM is just too high. I seem to recall 2200RPM for some reason. That is probably max for the engine, and still too fast for the excavator. I don't need to make change out of the hydro pumps.
