alan walker
Good evening, this forum has been very helpful to me over the years, but now I need help.
I have a case 590 super l series 2 powershift, When I engage the parking brake, I lose power to the trans controller.
The park brake switches are working, the seat lock switch is disabled, but it works as it should when it is hooked up.
The other suspicious thing or two, is that there is a wire hanging down that looks like it needs a diode, but its empty, and it makes no difference when I swap in a different diode.
The diff lock solenoid clicks even with the relay removed, but that doesnt change the problem either.
When I engage the parking brake power is lost from the clutch relay , and that seems to kill power to the trans controller.
I assume there is a bad wire somewhere but we've been over it twice with a fine tooth comb already.
