While I can't comment on the shock loads from farm implements (as I have no experience with them:beatsme), I will state this. The Scraper special 20 and 30 series John Deeres (ie 9520 or 9530) have heavier hitches and beefed up axles, because of the fact that they are pulling scrapers.
ANother thing I thought about today, and really don't know if it has any affect, all the weight from the pan is either at the rear of the pan or the tractor, on like a disk, the fulcrum for the weight is pretty much near the center to lift and lower the implement. While the fulcrum of weight on the pan is in the back of the implement, part of why the extra weights are towards the front, when you're hauling and hit a bump you can feel the Pan's weight pushing on the hitch trying to bounce the from of the tractor up and down.... so fun:Banghead.
This might be why I'm inclined to think that the construction field is more abusive on the tractor... :beatsme:drinkup
