Driving a mini 2 miles on country roads?
PJM
pnw
Can I do that? I have brand new rubber tracks on it. Don't have a trailer or easy access to a transporter. Is it an option to just drive it there? Would it just be excruciatingly slow (which I can deal with) or do I risk causing some damage to it or running afoul of the law?
seville009
CNY
no harm.....just slow
put a slow moving triangle and flashing light (like a snow plow beacon) on the rear if possible so idiots flying by see you
Bring a book to read......
OTG AuGres
Michigan
Hobbiest - Forestry and Wildlife Management
It’s over a mile from one side of my property to the other via the trail system. I try to plan my work and my travels...it’s a long ride across the trails from one side to another. Never figured any harm done, it’s just time.
PJM
pnw
UPDATE: Thank you for your help! Got the machine there just fine. I found it pulled to the right quite a bit. Had to adjust the line every couple of minutes. Can't say if the tracks are moving at different rates or it was the road camber.
Regarding the legality, a bunch of people, including the county sheriff passed me in the same direction like it was no thing. It did take about 45 minutes and I brought a podcast to listen to. Very loud and bouncy. Bose headphones canceled almost NO perceptible noise. There are speakers in the cab, but I couldn't see how to connect to them. It was a bit of a strain on the legs keeping the throttles forward, might have been the worst part.
I'm so happy to have my machine where I need it. Thanks again!
uffex
Lincoln UK
Admin
Good day
There are a number of examples of axle attachment to excavators enabling the machine to be towed by a tractor, could be worth consideration to save track wear.
Kind regards
Uffex
  • Like
Reactions: PJM
KSSS
excavation
Those BOSE noise cancelling head phones are amazing. When I have to track a long way, I have found that turning the machine around so you depress the foot feet down right in front of you is a lot more comfortable.
  • Like
Reactions: PJM
