ive seen it on the part manual but I can't find it on my backhoe no where lol where that hole is suppose to be there is no hole thereHi
Go to this site, it looks like it's number 32
https://partstore.casece.com/us/Gro...eehold/parts-search.html#epc::mr49912ar444543
make sure you have an electronic gauge 1980 could still have a hose direct to the gaugewas hoping someone with a 1980 580C could take a pics of theirs and maybe that would help
how would I be able to tell i'm new to case machine and I just bought this one and doing all the repairs myself as best I canmake sure you have an electronic gauge 1980 could still have a hose direct to the gauge
un bolt the dash panel lift it out enough to see whether theres a wire or rubber hose connected to to the op gauge-or see if there is a hose running from somewhere close to the oil filter-cooler back to the cabhow would I be able to tell i'm new to case machine and I just bought this one and doing all the repairs myself as best I can
ok thanks there a wire coming out of mine my gauge has one of those printed circuit boards with one of those double side plugs and a cable like a speedometerun bolt the dash panel lift it out enough to see whether theres a wire or rubber hose connected to to the op gauge-or see if there is a hose running from somewhere close to the oil filter-cooler back to the cab
alright there has to be a sending unit somewhere figure out the cam side of the block it will be in the oil galley- left side i thinkok thanks there a wire coming out of mine my gauge has one of those printed circuit boards with one of those double side plugs and a cable like a speedometer
Would the drivers side be the left side? Remember this is a very international forum and in some countries the drivers side would be on the right! And to not get too fussy on most tractor the "driver" sits centered behind the engine, well except for my Farmall BN!I have a late 70's 580c, ops is located on drivers side of engine just below fuel filter hope this helps
Is there by chance a wire hanging in that area not hooked to anything?I think I found it looks like they took it out and put a plug in it
