Good Heavy Pneumatic Hand Truck
Birken Vogt
Charter Member
Grass Valley, Ca
Looking for a good hand truck recommendation. Standard type with 2 wheels and pneumatic tires. Ours has lost both bearings and the tires are always going flat. We use it for yanking small home standby generators around on steep ground and such.
RZucker
Wherever I end up
Mechanic/welder
If you really know what you want, build one or have it built for you. 3/4" axle is the only way to go. I have destroyed quite a few cheapies with 5/8" axles moving oil drums.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
If u like the quality of your h. truck but the wheels are the problem..?? change the wheels..
Northern tool has some real decent ones & theres always H. Freight..
crane operator
sw missouri
One of the guys that works for me has a aluminum one that's built super heavy, like what the pepsi delivery guys have for taking cases into the stores. Look for one of those.
