Just purchased the 943 to replace my L783 NH. Knew it had a issue when i bought it........ Brand new motor just built by a 40yr in biz builder. Motor runs perfect! Hydro is my issue. Full throttle the machine driving speed is 25% of what it should be. It drives straight, turn the same both ways. Bucket/lift work as they should, no issues with the lift. This machine has a "charge pump" that should put out about 400 psi ..... check it in the system and was getting about 100 -160 psi (idle/full throttle). I THOUGHT great it's a new charge pump and fairly cheap (300.00). Went to the hydro shop that i use (very good bunch of hydro guys and a large hydro shop) to buy a new pump. He said let me check your pump out real quick. 2 mins later he had it completely apart and said this pump is fine .... almost no wear at all ..... everything looks/feels great. He puts it back together and says " you need to be looking somewhere else". CRUD! (oh, never charged me anything and i was there to buy a pump) Where do i go from here? What should i test? How do i test it? i did buy some flat caps for testing. I have the factory service manual in hardback so i can answer some question if asked. Thanks for ANY and ALL help, S
