Chris Withers
Not a cat mechanic, looking for info for what seal or seals are blown, could it be the clutch/brake assembly or is it a pinion seal, any helpful information would be appreciated, thanks in advance
I'm betting this.Release of pressure when you remove the level/drain plug.
Sn 8rc05702, removed axle cover from final drive center, was greeted with a release of air pressure followed by a deluge of oil, probably around an extra gallon beyond the fill level amount, the drive seems to function ok when cold, but gets progressively worse as it heats up until right drive pretty much ceases to function. No visible leaks.A Serial Number is always a good start, closely followed by a description of the symptoms.
You mention "Pressure in Right Final Drive", but what exactly do you mean.? Release of pressure when you remove the level/drain plug.?
Any oil leaking from anywhere..?
Answers to these questions.?How many total hours on the machine.?
What type/grade of oil are you using in the rear end.?
