All this talk about laying a dump on it's side on uneven ground. That's why there is a thing called the {cross gate belly dump}, for spreading you just can't beat it for long distance without speed bumps
in the spread. Grader operators like'em too. The problem with air ride is once it starts to lean depending on where the ride height valve is located {or ride height valves some systems use two} the valve
can cause the bag on the high side to help jack it over. Lets see KW 8 bag air { 8 bags $125.00 bucks apiece, air lines to leak for MR. DOT, air bags that start leaking and hard to find in the recess fold
area, ride height valves that leak and can get out of adjustment, four torque arms that take a beating every time you dump the air, lower torsion bar bushings to replace, center stands that can crack
and last but not least rear shocks to replace. Plus the u-joints don't like the angle when the air is dumped.
RTE 44, 46, 48,000 lb suspension, only has six main beam bushings that cost around $475.00 bucks. 2 fore and aft torque arms, four if it was spec-ed with lateral arms to keep the beams from moving
side to side. And two springs with bushings in the front hanger. Beams can be re-bushed in four hours, torque arms 35 minutes each. Universal Services in north of Seattle use to change out and rebuild
a complete set of beam bushings and torque arms in two hrs on appointment {while you wait} for $1,500 and you were good for a bunch of miles and years of operation. No air leaks, no shocks,
no air bags----no excess garbage. In my not so humble opinion. And with the addition of both rear drives with lockers you will go just about anywhere you want.
