fiat41b
Your correct john
I have one more question this engine was rebuilt and had 600 hrs on it when I purchased the tractor
new crank pistons injectors valves ect I got the paperwork with all the receipts from 2012
I have put only 400 hrs on it so now it s got app. 1000 hrs my question is if the work was done correctly could one of the liners have dropped so soon
would I have some contamination in one or the others compartments
I just had a message from that mechanic he mentioned the liner drop? and something about a shim- can you guys explain this process new to me
I used to have couple d8h pull tractor for scrapers they were good machine and fun to run. but the one I really liked dropped a liner something showed up as a sign
back then I had mechanics from the place I do business with handle my problems, its was a big dirt job, well they told me the engine had to be removed liner had dropped some machine work needed done I asked how much it was going to run close to 30,000
we reinstalled the heads new gaskets and sold the tractor both of them I wanted nothing to do with non spacer plate engines lesson 1.
well I bought this d9h because I got all the history on it and it was in really nice shape keep up
however not thinking to ask like a dummy if it was a spacer plated engine its not there are a lot of d9g's that have many hrs and are still going strong.
