Whaddya mean total loss..? It's still got four good wheels & tyres on it, even if the rest is junk....Had to go look at this after work monday. They were running it boomed clear up, on a bad slope, with a dozer on it with a chain. It still flipped over backwards, and almost flipped the dozer.
At least no one was hurt. I told them to just cut the boom out of it where it was laying, and have a wrecker drag up the house, and then the boom. Its a total loss.
The power company came up with a different transformer, so we didn't have to wait another 10 weeks to install the 2nd transformer at the hospital project.
There was a hump in the floor, and we ended up having to put the back half on standard alligator skates and push it with a forklift, I kept losing the air cushion on my air skates on the high spot in the floor. I knew the first one went too easy. But at least we got to put it in before they blocked up the wall and built the interior walls around the transformers.
The interior walls will have only a 8' wide doorway opening in front of each transformer, with the walls only 3' off the transformers. The transformers are 7' 11 1/2" wide. Should be fun when one of them doesn't work. They will only have a 10' door onto a loading dock on the outside.
Looks like they're building an oven. Don't see much ventilation. Those transformers put off a bunch of heat. Note the radiator fins on them. You're gonna have some fun sooner than later. Heat kills transformers.
What collateral damage will there be if one of these tx fails explosively with lots of sparks and fire and flaming oil?
I was in a forum with the designers of a FEDEX sorting facility. Their design was all about redundancy. Example. The building lighting was divided into multiple circuits. (nothing unusual) BUT... The individual fixtures were then alternated between the circuits. Lose one circuit, just lose every other light. Same with conveyors and equipment... multiples of back-ups. Fedex's product was reliable delivery service.
