Junkyard
I have a hydraulic torque wrench I have yet to use, deal was too good to pass up. Now I have a need but only have a pump made to run cylinders and such.
Question I have is can I add a regulator to the pump and run the wrench with it? It’s a 10,000 psi pump made to run all the single and double acting cylinders etc.
Is there more to a torque wrench pump than a regulator? I don’t mind buying a pump but if the one I have will work with a few changes then I’ll use it.
Thanks in advance for the help!
