Snorkel tb60 issues
BillG
S. Wisconsin
Absolutely, carb engines don't have most of the electronics that TBI units do. Also with the ecm you need the correct manual for proper troubleshooting. And manuals are probably the cheapest parts that you can buy when you consider the alternative.
Snorkel issues
Tennessee
I googled that model number and found a lift with that motor so I assumed it was it. I'll look at motor tomorrow and get exact info...also can I check the codes with personal computer and if so how do I connect it
BillG
S. Wisconsin
Read the bulletin that I posted, everything is there. Codes, what it's associated with and how to count the flashes.
Snorkel issues
Tennessee
I started searching right after I asked lol. Thanks for all the help. I know messing with me been like helping a 5 year old.
Snorkel issues
Tennessee
New question we bought another lift same kind but diesel theres alot of movement in the body turrent. Is this gonna be a major fix
BillG
S. Wisconsin
You are kidding correct? Let me give you a piece of advise "CALL A REPUTABLE DEALER". You are getting in way over your head and in danger of three things -
1. Spending a whole lot of $$$$ for nothing.
2. Making an otherwise usable piece of equipment dangerous.
3. Turning an otherwise usable piece of equipment into a scrapyard candidate.
Not only the above but after all of this you still have not supplied a serial number.
Snorkel issues
Tennessee
983895...new question...we changed throttle body. Starts and runs. But now pedal wont work on platform. And you can use controls with out using pedal. Swapped out pedal with other lift pedal works and when you use controls without pedal it bogs down motor and kills it.
