Volvo EC -240 One track extremely slow along with swing
RKC
India
Left side track of my Volvo EC-240 excavator is extremely slow along with swing function in either direction. Operator is feeling jerks at the pilot lever while operating the swing. We have changed turning/rotary manifold joint seals but problem persists. Any help would be really appreciated.
uffex
Lincoln UK
Admin
Good day RKC
A few questions how many hours has the machine - have you checked the pressures - How is the arm is that oK or is it slow also ?
Kind regards
Uffex
RKC
India
We swapped the hydraulic pump to control valve hoses. Swing and left hand track has become alright but the right track and other functions became slow. We suspect failure of one hydraulic pump and will inspect that. The machine has done 14k + hrs.
uffex
Lincoln UK
Admin
Good day
Before you condemn the pump check that the FR/FL hose drains down when you operate swing etc. if that is correct check the filters for signs of injury - listen at the pump under load - measure the output pressure at full load. Normally the pumps last 10k at least so it may be time to rebuild / replace.
Kind regards
Uffex
  • Like
Reactions: RKC
RKC
India
Thanks for the response. Could you please specify which front right/left hose i should exactly look at?
uffex
Lincoln UK
Admin
Good day RKC
Please see attached.
Kind regards
Uffex
  • EC240 Neg.pdf
twr
texas
We have one doing same thing pulled pump customer sent in for rebuild but it back on ran about 6 hrs and did same thing.
uffex
Lincoln UK
Admin
Good day twr
Did you check out the negative control line ?
Kind regards
Uffex
funwithfuel
Will county Illinois
Mechanic
Check your servile oil to your RCVs. The inlet fitting to the manifold is a Filter fitting. Often times you will find my line on stop against the fitting from the inner jacket of one of your hoses. Obviously you're going to want to start with your left joystick.
funwithfuel
Mechanic
Yes then please proceed forward with checking me servo oil pressure and flow at your remote control valves. I would suspect you will find trash in the lines jammed up against the fitting
RKC
India
We are cleaning the hydraulic pump regulator of debris which isn't giving proper delivery. Will update soon
TVA
USA
Debris in your regulator came from MCV center gallery! There’s very high chance your NFC relief valve is full of it too!
TVA
USA
Hi, Funwithfuel!!! Nice to “see” you again! Been a while! There’s fella on Doosan refurbishment project looking for hyd. System cleaning instructions, can you help him!?
TVA
USA
I would recommend full pilot system and NFC clean up! You might be surprised how faster that machine will become!
RKC
India
Sorry for the delayed response, heavy rains here ... Thanks for all the advice on negative control . We opened the pump regulator, cleaned it and all functions appear to be working now.
Stodus68
Pennsylvania
I know this post is old but I am having similar issue. Was wondering if the regulator is between the pumps
funwithfuel
Mechanic
Step one, please open a new thread with your serial number and model number in the appropriate section. All are not the same, even though a symptom might be similar, the root cause could be very different. Step 2 measure track sag per ops manual. Adjust same , run and recheck. Check fluid in travel gear boxes. Make sure there is oil and it doesn't look like antiseize.
